16 Vanguard heads, Nubs,fmints?
Results 1 to 7 of 7
Thread: 16 Vanguard heads, Nubs,fmints?
    OK, dropped an exhaust valve guide on the right side or front head of Sandy, as tempted as I am to just tap it back in I think I'll have them replaced.
    So here's my question to which I think I know the answer. Are all the 16 heads interchangeable provided they are from the same side? 1 head stamped 30/ 1-3 and other stamped 30/ 1-G.
    Thanks to all in advance.
    Sep 2013
    Waldo Wi
    941
    Early and late style, early has larger rocker studs with a stud to hold the valve cover and uses different rocker arms. late uses the bolt n two piece rockers.
    Rockers look the same and studs interchange, good to go?
    Sep 2013
    Waldo Wi
    941
    Yep
    Great thanks, saved the day and Lindsay will be happy that Sandy is once again good to go.
    Jul 2011
    Garner, NC
    865
    Sorry so late Jim,, but looks like Nubs "squared you away". Glad to hear that Sandy is back running again!!
    Good info Nubs! Thanks also!!
    BIGFOOT ALUMNI
    Thanks Fred, running full power but now smoking will be trying seals but may have hurt the rings on the rideback. Also only had steel gasket here so that cyl has a little more comp. than the other.
