Conquest coil
Results 1 to 8 of 8
Thread: Conquest coil
    Jan 2013
    Sidney Ohio
    509
    Conquest coil
    Took ride today to check stands and just to be out. Everything was going good and all of a sudden I lost some power. Limped it back to the truck, popped the good and the front plug wire we off. So I pushed it back on and took off again. About 800 yards from the truck, started acting up again. Not sure why it won't stay on the plug. But i assume I am going to need to replace that coil. And if if I do that I may as well replace both. And if I do that I may as well change out the plugs while I'm at it.
    My question is, should I get everything from an Argo dealer? Or just go to a small engine repair shop?
    Jan 2013
    Sidney Ohio
    509
    Just stumbled across these.
    http://www.4wheelparts.com/Performan...FU9k7AoddVgAvA
    Not sure if they would work or not.
    Fairbanks AK
    1,456
    Those look like they would work if they are 7 mm. I didn't see the wire size listed. If you need parts for the Kawasaki fd620 go to small engine place first.
    Jan 2013
    Sidney Ohio
    509
    I found this one. 268-0457 - Spark Plug Boot, Briggs & Stratton 4124, 493880, 493880S, 66538, 66538S
    Just wonder if it wouldn't best to replace the coil. That way I don't have to worry about it in the future.
    Oct 2008
    Thornton, CO
    646
    Did you try giving the metal cup inside the boot a little squeeze with a pair of pliers? Do so with care; you want to tighten it, not crush it. When it's right it will snap onto the plug.
    Jan 2013
    Sidney Ohio
    509
    I have bit tried that. I will, thanks for the tip.
    Fairbanks AK
    1,456
    Had a conquest in today and the plug cap unscrews off the wire and should be available seperate. Similar to snowmobile or dirt bike.
    Jan 2013
    Sidney Ohio
    509
    That's exactly what happened. The end was still in the wire. So I pulled it out, screwed it back on the plug and I am back in business. Thanks guys.
