Briggs and stratton 18hp help please
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 46
Thread: Briggs and stratton 18hp help please
    May 2014
    LANCASHIRE, UK
    203
    P.S Been looking at starter moors on ebay and they sell back plates with the brushes built in? when I get chance I will remove the starter motor to see if its dead or not , and let you guys know, also been looking at Solenoids on ebay for WESTWOOD TRACTOR, looks sames as the ones Max fitted , but it has two spade connectors at the bottom, I know one goes to the green wire, but whats the other for? and can I use this one ( ebay item number 390931066324)
    Richie
    May 2014
    LANCASHIRE, UK
    203
    Hi again, I put the volt meter on the green wire (spade) on the solenoid and the other end of the volt meter on the earthing strap, got the wife to start the engine and it fired up right away!!! so am I right in thinking this is an earth problem?
    May 2014
    LANCASHIRE, UK
    203
    Hi akcrawler, I put the volt meter on the green wire (spade) on the solenoid and the other end of the volt meter on the earthing strap, got the wife to start the engine and it fired up right away!!! so am I right in thinking this is an earth problem?
    If I understood what you're describing it now sound as if some Brit has been playing with your wiring. Could be because of the standard parts that are over there compared to here.
    To me ,if I understood you, when you ground the small terminal on the solenoid it starts? If so you will need to get a power excited starter relay, the ground(earth) excited starter relays have not been used for sometime over here. Your switch may have also been changed.
    Next there are 2 types of switches used in the Max machines a 5 wire and a 7 wire here;
    http://www.6x6world.com/images/recre...n-to-7-pin.pdf
    Both the switches are Indak switches that ground when shut off, one has a off/run/start set up and the 7 wire has a off/run/accessory,start setup. Generally the 7 wire will have the headlights hooked to the acc. position, the 5 wire will either always have the headlights on or need a separate headlight switch.
    The shut down wire will run from the switch to the engine where it connects to a very small stud on the upper side of the engine shroud.
  5. #15
    May 2014
    LANCASHIRE, UK
    203
    Will check tomorrow, going to change the solenoid too, as its not bolted down, is the green wire positive or a ground? just when I had the volt meter on it ( red clamp on volt meter) and the black clamp on the ground) then turned the key and it started, this fault only just started since raisingthe top.
  6. #16
    May 2014
    LANCASHIRE, UK
    203
    Hi again, I have taken the side casingof the engine with the pull start on, I cant see any wires? engine kill wire I am looking for, seen in posts that its near the starter and may of came off, any one point me in the right direction please?
  7. #17
    Sep 2013
    Waldo Wi
    941
    There should be a wire that runs from one coil to the other, from there it clips to a post on the fan housing.
    578A is what your looking for
    http://www.partstree.com/parts/?lc=b...E1&dn=06700014
  8. #18
    Sep 2013
    Waldo Wi
    941
    here is pic of a Members vanguard, its the black wire on the left.
  9. #19
    May 2014
    LANCASHIRE, UK
    203
    Hi Nubs
    I dont have that bolt, the t plug (red wire and black) the black was bolted the the skid steer unit and not the engine, i have now bolted it to the engine and still nothing, I noticed that my key switch has now black wire only 2 red ,1 green and a white wire, one spare one but its live all the time, I do have a push in switch that you need to keep pressed that has black wires, after pressing it still the engine runs. I am pulling my hair out now lol
  10. #20
    Sep 2013
    Waldo Wi
    941
    can You see the wire that goes from both coils? if that wire is grounded to the engine it has to shut down. or that wire has a break in it.
