Sleeving a T-20
Results 1 to 10 of 12
Thread: Sleeving a T-20
    Jul 2011
    Garner, NC
    865
    Sleeving a T-20
    Hello everyone!
    I will start by saying that I'm a little more than frustrated at the moment with the T-20 that resides in my Hustler! I had an issue with shifting into reverse for over two years now. My diamond shifter holes were worn pretty bad. I have replaced the diamond shifters twice before purchasing a used set of t-20 cases just weeks prior to the fall Busco ride. The "new to me but used" cases allowed me to shift smoothly during the weekend of the ride, but I was losing transmission fluid like crazy. Yup, you guessed it,,,, the plunger holes on the "new to me but old cases" were worn, so, thanks to Lewis for letting me use his small funnel, and about 2 quarts of tranny fluid, I was still able to ride and have fun. So now I'm ready to fix the issue without having to break the "hobby bank". The solution is to sleeve my old casing, both the diamond and plunger/brake band holes. The problem that I'm facing is the resources to accurately drill or bore the holes to accept brass or stainless sleeving! Does anyone know of a member or business that I can ship my cases to, that will drill/bore the holes. If there is a member that can, I will supply the sleeves and of course shipping and labor is not an issue so far as that I don't break my "hobby bank"!! I do appreciate any and all responses!
    Fred
    BIGFOOT ALUMNI
    Dec 2012
    Youngstown, Ohio
    1,003
    This is just a suggesting but maybe you can sleeve the plungers themselves. It would be easier to press them into something and cut them down with a lathe. That is something any engine machine shop could do for you. Might even be cheaper too.
    Jul 2011
    Garner, NC
    865
    Thanks for the reply smudvapor, I never considered that route! I beleive that it would be cheaper!
    BIGFOOT ALUMNI
    If you go "that route" you will probably want to ream the cases as the aluminum is likely wore as opposed to the plungers.
    The other route would probably be somewhere in Arizona.
    Aug 2013
    Hilton head SC
    315
    As long as the holes are not out of round from wear, making the plungers bigger should work. I've got a lot of friends in the machining industry Fred, if you don't find a solution call me and I'll set you up with someone in savannah.. Norm
    Nov 2009
    2,910
    Fred, check the plunger holes for scoring. I had a case once that I took a brake cyl hone to ($2.99 tool) and cleaned it right up. I have also seen early cases with plunger sleeves epoxied in place.
    Fairbanks AK
    1,456
    I see quite a few factory cases with sleeves. I believe these were mostly poor castings that were repaired insted of scrapped. I would contact whipper for any ideas. Honing the bores will usually remove the scratches with out making them to much oversize.
    Hey Fred, I bought one set of double o-ring plungers from RI a couple years ago and used them in two T-20s. Seems to me that you only really need them on the lower plungers.
    Just an FYI to save the "hobby bank."
Tags for this Thread
