kohler engines
Results 1 to 10 of 13
Thread: kohler engines
    Aug 2007
    Wells Maine
    422
    kohler engines
    I was wondering is there a difference bewteen the kohler 23hp and the kohler25 hp as for power would it be worth up grading to a 25 in my max 4 I also see they sell in northern hydraulics a 27hp motor too.
    Central, Massachusetts
    48
    Hi junk. I know this is a bit late in coming but I have been away for a while. I don’t think it is worth the swap at all. I had a max4 with an 18 Briggs and my new one has the 25 hp Kohler and I can’t tell the difference at all. Save the $$
    Oh ya the biggest difference I can see so far is the Kohler is a lot Quieter
    Dec 2007
    eden nc
    1,484
    i have a 18 briggs in my II and a 23 k in the IV not munchg differance . if you go from a 18 2 a 27 yes there is a differance .i rode a 27 kaw iv and there is right munch differance there . robbie
    Aug 2007
    Wells Maine
    422
    engine
    I ended up buying different sprockets for the t-20 to drop down from a 15 tooth to a 13 tooth like mightymax did hows yours for power rdr I think the 23hp is not enough for the max 4 with 26" tires
    Dec 2007
    eden nc
    1,484
    Quote Originally Posted by thejunkman View Post
    you are right
    Aug 2007
    Wells Maine
    422
    engine
    rdr does your belt squeel at times when taking off?
    3,285
    [ QOUTE ] does your belt squeel at times when taking off ?
    junkman ,
    I ride with boncrshr who has a Hustler 950 with a 20 hp Honda motor in it . He has also done the red spring clutch modification too . He also went to a 40 tooth sprocket which helped a lot . In situations though , when his Honda motor is put under a lot of strain , his belt will squeel some times too .
    He was told that a Clutch off of a Max IV would cure this problem. ? Any one know about this ?
    Aug 2007
    Wells Maine
    422
    engine
    I have never heard of this but I do know you can change your springs in the clutch to make rpm engagement a little higher when taking off.
    Dec 2007
    eden nc
    1,484
    na i use napa belt dressing but be carful a verry little goes a long way: robbie
    Aug 2007
    Wells Maine
    422
    engine
    But before you used the napa belt dressing did yours squeel and what kind of dressing napa or crc?
