Splined Spockets
Results 1 to 5 of 5
Thread: Splined Spockets
    Splined Spockets
    Hi All
    If I am unable to remove the set screws on my sprockets I will be cutting them off.( my patience is wearing thin) where is a good place to buy new ones? I am more concerned about quality than cost.. I will be needing the jack shaft on the right side for sure as the #60 sprocket for the center tire is pointed..
    thanks larry
    Ask Whipper-ag on this site.
    2,633
    had the same problem on my max 2. just bought 2 new center axle sprockets from richards relics. look as good and heavy duty as the originals. after lot's of drilling i got the set screw removed. good luck. john boy va.
    Jun 2014
    North Eastern NC
    370
    spray with nut buster, let set a day. use left hand drill bit and drill at slow speed, they may screw out as you drill deeper.
    Mar 2011
    Colonial Heights, VA
    497
    Put a heat gun to it so you can heat them up, sometimes there is loctite on these and the heat guns burns that up along with any dirt and sand in the threads.
