2000 MX II Prts list
Results 1 to 6 of 6
Thread: 2000 MX II Prts list
    HI All
    After several hrs of researching parts for my overhaul I have decided to use these parts and venders for my overhaul, I hope this will help others.
    Chains, MFG Supply
    Nomenclature
    5200-ring-102-w1-520 O-ring chain 102 pins $159.12
    520O-CL-W1 - 520 O-Ring Motorcycle Chain Connecting Link 5 $19.95
    530O-RING - 530 O-Ring ATV Chain. 182 pin 182 pin $89.18
    530O-CL-W1 - 530 O-RIng Motorcycle Chain Connecting Lin $19.95
    Total $288.20
    Buffalo Bearing, 714-874-1720
    Nomenclature Qty Price Total
    HC 207-20 R3 outer bearing 12 $17.44 $209.28
    SA206-20 Inner bearing 6 $13.07 $78.42
    PF207 outer bearing plate 6 sets $12.96 $77.76
    Total $365.46
    Adair Argo sales, 877-683-3694
    6 Sets synthetic bearings 6 $60.00 $60.00
    Total $60.00
    Carts Plus 888-861-2640
    High Rev Kit 1 $90.00 $90.00
    tiny tach 1 $35 $35
    Total $124.00
    Mudd- Ox 1-888-898-2746
    70117 center splined sprocket 2 $154.32 $308.64
    70140 front/rear sprocket 4 $60.39 $241.56
    70545 L/H jackshaft 1 $97.87 $97.87
    70550 R/H jackshaft 1 $83.21 $83.21
    Total $731.28
    Previous items already rebuilt 2 years ago, driven clutch with red spring, complete T20 overhaul with new bands and bearings, brakes and blue rollers and yellow springs for drive clutch (just received those)
    I will have about 3k total when all said and done and it will be a new machine for sure All parts will be here this week and then the real fun starts.
    I want to thank all the people who post on this site as it has been a tremendous help to me and a huge shout out to Mike for keeping this site the best on the internet.
    Larry
    Fairbanks AK
    1,456
    Looks like a good list , double check the inner bearing # for turned down axles its 206-17.
    2,633
    thanks larry, i'm doing the same on my max 2. it's really fun when all the new '' clean '' parts are in and assembly begins . thought about a new machine, but for way less money can make it almost like new. enjoy, john boy va.
    Thanks
    I have the splined axels so all is good with my bearings
    Larry
    Jul 2012
    Lancaster N.Y.
    205
    garretttpe. There are 2 different splined axle inside bearing diameters. And I know this because my machine had 2 different styles when I got it and its a 2001. Has some set screw stlye sprocket axles which are the number you listed and couple axles that have the snap rings for gear alignment and them have a turned down end so uses a different bearing that msafia said. just so you know.
    Surfer Dude
    Gotcha, good info. I have the solid splined ones that are not turned down. All this info is why this is an awesome forum.
    Thanks
