New Max II redesign?
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 55 of 55
Thread: New Max II redesign?
  1. #51
    Aug 2011
    Kotzebue, Alaska
    1,209
    It crossed my mind to blend a II top to a IV top, keeping the engine area of the IV. It would be front bench with aluggage compartment behind where the rear bench used to be. Use the Buff roll cage.
  2. #52
    May 2014
    Talkeetna, AK
    155
    Almost Drew.
    Some folks really seem to like the look of the Max II. If a guy can figure out how to put a Max II top on for looks and keep the larger lower tub of the Max IV for tire size, he gets pretty close to what the original post was asking without compromising the lower tub. That would give him the trim looks of the Max II with the larger tub of the Max IV. The II has a raised area at the back of the lower tub which could cause problems in the matchup. If one could cut the top of the II off at that point and weld on the Max IV top from there back, it just might work. The other option might be to add a sheet metal adapter between the upper and lower in that area and just keep the entire II top. Any of this would be tough to do without making it look like a cobbled up mess (at least for me). It might just end up looking like a Frankenstien Monster Machine.
  3. #53
    Meadville, Pa
    3,286
    I think want you want or would be satisfied with is buggymans big blue max II Bigfoot.
  4. #54
    Sep 2012
    Hanover,PA
    1,012
    I always liked to look of the Amphicat. It would be COOL to buld a Max II to look like that. To bad you can't get That body & tub in the newer poly and transplant the frame and drive line !!
  5. #55
    Nov 2009
    2,910
    Quote Originally Posted by amphibious drew View Post
    [IMG][/IMG]
