650 HD Admiral tranny servicing question
Results 1 to 4 of 4
Thread: 650 HD Admiral tranny servicing question
    May 2008
    Kirkland Lake, Ontario
    64
    Hi All,
    I was doing the end of season servicing and changing the tranny fluid is of course part of that. So i warmed up the machine, pulled the plug to drain, then inserted the vacuum hose to make sure i got as much fluid as possible. Then i refilled it to the mid point on the indicator glass, as per the manual. It certainly did not take the 1.1l it was supposed to. Waited a bit and fired it up and ran it. The fluid level in the glass dropped to nothing while the machine was running (F-N-R for few minutes). Shut it off and then watched as fluid came back up in the glass...but now it is almost to the top of the glass, and it doesn't go down again.
    Has anyone else experienced this? Do i drain some off? This is what, no. 4 or 5 fluid change; never noticed this before.
    Pretty sure you're fine shorty! I imagine some of the new stuff was just hung up in the gears and when it got warmed up it all ran down to the bottom. The difference from mid sight glass to top of sight glass isn't much and is certainly within the range of the old dip stick High/Low method.
    Fairbanks AK
    1,456
    I find the oil gets air in it when run and goes over full as soon as it moves. Most have to sit a day to go down to the level it was installed to. If your not using a metal tube bent to go into the bottom of gear case you can't replace the full amount of oil listed in manual. I use a 5/16" tube bent to about 9" radius. It goes in to the right side and rotates down.
    May 2008
    64
    Thanks, guys. It was just one of those WTH moments...just never noticed it before. Will check again tomorrow. With the temps getting cold, everything slows down. Me most of all! ;-)
Tags for this Thread
