Magnum flywheel
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 75
Thread: Magnum flywheel
    Magnum flywheel
    How long usually does the flywheel that creates electricity to charge the battery last for I don't think it has ever been replaced in my 1992 magnum so would that be the reason why my battery is not charging
    Jun 2015
    Kenai, AK
    152
    The flywheel should never wear out. It's just a big hunk of cast iron. There are magnets glued to the inside & they MAY have broken loose but more likely it's the voltage regulator or stator.
    Sep 2012
    Sault Ste Marie, ON
    66
    I would suggest checking or replacing the rectifier/regulator. I had an Argo I/C with the Kohler 17 hp engine that stopped charging. At first I misdiagnosed it - I bought a stator, thinking that it was the culprit. But it was the rectifier/regulator. Once I replaced it, the engine charged just fine.
    I'm assuming of course that you have a Kohler engine.
    Yes I have a Koehler engine 18 hp red so it is most likely the stator or regulator. How hard is it to replace the stator
    Dec 2012
    Wildwood Fl
    126
    you can test the stator out put with a volt meter if you have one. disconnect the two outside leads on the rectifier and connect volt meter to 200 volts a/c and crank engine run up rpms and it should read between 25 and 30 volts a/c. if you don't get that voltage it is not working. if you get 25/30 volts a/c than test rectifier it will be the center lead and it should read 13/15 volts dc.
    Ok so cost and part number for a stator for Koehler magnum
    1980's Kohler Magnum 18hp Motor ~ Stator
    Would the connections work? Someone suggest for me that is not to expensive and still works that would for a m18 kohler
    Fairbanks AK
    1,456
    Before purchasing the stator test as described above. AC voltage should be above 28 volts. Also test the resistance of the coil on the same two wires. 15 amp system is supposed to read .1-.2 ohms. 25 amp system is supposed to be .064-.096 ohms. The eBay one you posted should fit. It appears to be a 25 amp coil. If your resistance shows open or 0 ohm the coil is bad. Sorry to say they are usually destroyed by loose magnets from the flywheel. Test it properly before spending any money on parts. You also must have battery voltage to center terminal on regulator with engine off. A bad fuse will kill the charging system.
    Ok the only fusses are in the fuse block right no where else
    Sep 2013
    Waldo Wi
    941
    Quote Originally Posted by curtisbyrne View Post
    Have You checked the system with a meter yet??
