Ed, what tires do you have on the Max? You mention the Rawhides and with the 16hp engine, I'd guess you have the 21" or 22" tires. These tires are simply too small for a larger vehicle like the Max IV. No where near enough floatation and that is why it bobs like a cork. The Max IV really needs the 26" tires to achieve its real performance level. The larger tires will give you the floatation you need in the water, amazing water speed, almost 10" of ground clearance, and some of the best mudding ability you can get from an amphib. Those 26" tires require solid axles and I would recommend at least the 20hp engine. All types of tires can be run as low as 1psi with the newer rims, or about 3psi with pre-'99 rims. Also, they must be on backwards to paddle water to move the vehicle.
