I recently purchased a 97 MAX IV. I had to replace the belt because the owner wanted to take it for a last hoorah. Well I didn't get to try it prior to purchase but he did show me the tracks where he rode it. So i figured it did work and would have to take the mans word about it. Any way after replacing the belt and trying it out. It would not stay in reverse and it would not track to the left. Did some playing around with it and did get it to work a couple of times. Did some searching on this site and everything pointed to the Diamond plate pins. So off the motor and removed the Diamond plates and the left side was flat sided. Who ever changed the fluid put the vent plug at the top. Also I noticed the the top bolt to adjust bands was way out (After more inspecting. I found that the plunger to the band is stuck out. I can tap on it to get it back in. But when I pull back on the stick it stays out. I have tried to work it in and out.) Should I try to re-adjust the bands or is this normal. I attached a picture. Also what is the purpose of the springs on the shifting rods. They do not apply any pressure at all. Is there an adjustment for these springs? I did manage to remove 25oz of tran fluid. It was dirty black.
Is there a way to free up the plunger without tearing the tranny apart?
