Vanguard 23 questions
Results 1 to 4 of 4
Thread: Vanguard 23 questions
    Ive got a line on a pretty cheap brand new Vanny 23. However the air cleaner cover states it is a LP and NG motor.
    Also the engine will need a new wiring harness, front shroud and a different crank because the one in it is tapered. I have an 18 vanguard but I'd rather not have to rob the crank from it.
    So my questions:
    Will the existing carb work with gasoline? The seller says that because there is a fuel hookup on the carb it is no longer a LP/NG motor
    Does anybody know any ballpark costs for the wiring harness and shroud? I hear a new crank is about $150.
    Thanks guys
    Sep 2013
    Waldo Wi
    941
    Would need to have a carb, LP setup will not run gasoline. a new crankshaft is more like $275 and it can't be removed without pulling the pistons and rods.
    Photos ?
    That's what I figured. I will try to post some pictures up soon. Thanks for your help guys
    I talked to my mechanic about it, apparently there is a lot more that goes into converting an LP motor into a gasoline motor than just the carb. I'm gonna hold off, even if it is a $300 motor.
