Max ll t20 transmission issues
Results 11 to 20 of 36
Thread: Max ll t20 transmission issues
    Northern VA
    2,766
    Quote Originally Posted by Joe H View Post
    Guess it would depend on what the 300.00 includes. If he is going to tear it completely down, hot tank the cases, make sure that everything is within spec including the bearings, bushings and wear surfaces and repair or replace as needed then that sounds like a bargain to me. Now if it just includes tearing it down, finding the malfunction and replacing parts, and put Orings in it and call it a rebuild like some do it not worth the money.
    Exactly.
    Apr 2016
    VT
    266
    RichardsRelic's seems to be a reputable source. If you question what is included for the price, I am sure that they will tell you.
    Meadville, Pa
    3,286
    Quote Originally Posted by hipowerone View Post
    No, not really. He has burned a lot of people with crappy parts. In my opinion, he is best avoided.
    Reputable source? Definitely not. I could tell countless stories of people that I've come across that have been burned by him. Including the transmission that he supposedly "rebuilt" for someone that I helped fix the correct way. It looked like it was only opened up and then put back together.....no new parts installed or anything.
    Quote Originally Posted by amphibious drew View Post
    Drew, you hit the nail right on the head! Buyer beware......avoid him as a source of parts. There are higher quality and lower priced options out there.
  5. #15
    I have decided to fix the tranny myself. I fixed the Briggs Vanguard motor that wouldn't shut down (a new kill wire attached to the magnetos). Question... should I attempt to just install the bands and plunger O rings or go for the complete rebuild? That is if it's just a broken band and the drum isn't scored. Who do you suggest is the best source for parts?
  6. #16
    Butler, PA
    191
    Help me out JP, what are the sources for higher quality parts? I have purchased wheel adapters from Richard and from another source, Richards are WAY better!! His are 1/4 inch thick with pressed in studs that actually line up with the wheel holes correctly. The others were made of 1\8 with bolts welded on crooked, where's the value in that?
  7. #17
    Meadville, Pa
    3,286
    Quote Originally Posted by boyerbl View Post
    That's a great option and will not only save you money, but help you to learn about how it operates better. I would suggest replacing all seals and gaskets. Check your bearings out well too. If they are showing signs of wear or play, go ahead and replace them. I believe mudd-Ox sells a seal kit as well as the bearings and bands if needed. If the drum is too bad, post in the wanted thread on here. I'm sure you can source a good one much cheaper here than anywhere else, but feel free to shop around. Also, getting bands relined is a good option to save money.
  8. #18
    Hi Joe, I can help you out for better quality and LOWER priced parts if you need wheel adapters. I got them from Buffalo Bearing actually......1/4" thick with pressed in studs that lined up with the wheel holes perfectly too. And much better service, with no negative condescending attitude from the guys there.
  9. #19
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by jpswift1 View Post
    how much?? curious! Thanks
  10. #20
    A T20 rebuild question... When I replace the bands how hard is it to remove the old pins on the plungers that the bolts attach to?
