two-stroke brain fart idea
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: two-stroke brain fart idea
    Quote Originally Posted by Nubs View Post
    most all golf carts til the late 80s ran 2 cycles with starter/gens, started backwards for reverse.
    Is the driven on a golf cart made different so it works in both directions? Ours are wound for one direction.
    Oct 2008
    Thornton, CO
    646
    Now that's interesting.
    Perhaps they don't care that it stays in the lowest gear for reverse so there is no need for the driven to change.
    Sep 2013
    Waldo Wi
    941
    Made the same, JohnF hit it on the head. acts like 1/2 speed in reverse deal.
    Northern VA
    2,766
    The ignition timing's got to be way late too, doesn't it? Then again; you're in reverse so you don't use it that often and you're going slow.
  5. #15
    Mar 2008
    Almonte Ontario
    19
    The penguin engine uses two sets of points, one for each direction. It also uses a reversing solenoid to switch the direction of the starter/ generator.
  6. #16
    Mar 2008
    Almonte Ontario
    19
    The rotor for the starter/generator on the Villiers motor in the Penguin and Beaver is keyed onto the crankshaft so there is no bendix. I believe that golf carts used a belt driven starter generator, so again no bendix. If I remember correctly the way the ignition cam is ground on the golf cart the ignition timing is correct for reverse. Is the driven on the golf cart torque sensitive, with a helix ? I have a Snow Cruiser snowmobile with a speed sensitive driven clutch, it has no helix. The movable half of the driven slides on pins so it would not be affected by direction. It is a Salsbury unit if I recall correctly and this Snow Cruiser has no form of reverse.
  7. #17
    Mar 2015
    Pickering, Ontario
    633
    I've owned several snowmobiles with electronic reverse. It is accomplished through electronic timing, when you engage reverse the spark is cut and on the final revolution the engine will fire back up in reverse rotation. I've had Polaris and Bombardier machines with this feature, the only "real" negative is you cannot stay in reverse for any length of time as the engines are starved for oil while running in reverse, the oil injection pumps only work in forward rotation. I guess if you wanted to premix your fuel this wouldn't be an issue any longer.
    Trying to adapt an engine to reverse rotation would require a fair amount of work, settting it up to run well in both directions is a HUGE job.
  8. #18
    Aug 2017
    Oregon
    3
    Any 2 stroke will run in reverse. Only major factor that comes into play is spark timing. You either need a coil set to the opposite timing or electronic ingnition to set the timing. This is a common issue in the Goped world.
  9. #19
    Oct 2010
    Wells Maine
    98
    I had a 1970 Mercury 250ER snowmobile that had reverse. You had to shut it down, hit a switch and restart it and it ran backwards. It was a real advancement back then and the coolest looking machine.
