The dusters take pucks which are weights. So you will probably have to install all the pucks it will hold. I think a two stroke only uses half the pucks. But i think generator's could have up to 3 different tapers so make sure the clutch fits before buying the pucks. Looks to me like the generator uses a 5 degree taper. Most snowmobiles use a 1/10 also known as 33mm taper which comes out to 5.71059 degrees taper. Just be careful and make sure it fits correctly don't want it flying off...
Pucks on ebay and generator taper chart.
Depending on the length of the shaft before the taper and the diameter you maybe able to just cut a key way, keep us informed.
pull the generator head off and post a picture, the adapters work well although i have not used the one posted. the cranks are not easy to replace, gotta pull the pistons n rods in order to slide it out.
Thanks Nubs!!!
Good luck on this one . I am interested in seeing if there is an adapter ?
