20hp vanguard
Results 1 to 10 of 32
Thread: 20hp vanguard
    Jan 2014
    clifton IL
    812
    20hp vanguard
    Ok guys. Goin to look at a 20 hp vanguard out of a generator with 100 hours on it. Will have to buy a carb to get from lp to gas again,what ya think this is worth??? Or go with a predator??
    Thanks for any input!!
    You will probably need a crankshaft as that will be tapered.
    Jan 2014
    clifton IL
    812
    oh. Well I don't think I want any part of that!!
    Thanks for that heads up!!
    Buffalo, NY area
    2,968
    Well they do make adapters to get you from a tapered shaft up to 1" keyed...
    Crank Shaft Adapter Taper to 1" inch Generator Pressure Washer Engine Bushing | eBay
    Jan 2014
    clifton IL
    812
    Well I may be back in business then!! 150 bux for this motor that looks brand new!!
    Thanks Mike!
    Jan 2014
    clifton IL
    812
    hey Mike have any of you done this with a clutch installed??? this adapter will work with a clutch is what I'm asking.
    Buffalo, NY area
    2,968
    I've not had to use one, but the whole idea behind them is that they bush the tapered crank up to a 1" keyed shaft, which is what the 780 Comet fits on.
    Jan 2014
    clifton IL
    812
    Ok.Thanks mike,I may get this motor and split from generator and see if this will work. price is right i think!!!
    Jan 2014
    clifton IL
    812
    Ok,it's a 23hp vanduard and it was free of charge so I'm gonna give that adapter Mike shared and see what happens!!!
    I will prolly be bothering some of you guys when it comes to the wiring of this motor also!!
    Thanks
    Dave Phelps
    Fairbanks AK
    1,456
    Dave I have a tapered comet duster I'll put in a box I you pay freight. You will need a spring and pucks but I think
    It's funtcional. Was on a 2 stroke if taper is the same. I run one on my max 2.
