Calling all 23 Vanguard Gurus
Results 1 to 2 of 2
Thread: Calling all 23 Vanguard Gurus
    Got a 23 I've been working on and getting work done to. Been a long and to be honest terrible process. By the way don't let precision cams touch your heads.
    Any way. I finally got my motor together.
    First run I had bad gas thanks the the nice storm we just had in FL. Motor would only rev to 3600rpm under load and governor hit at 3800 with no load. Also there was a lot of surging happening at lower rpms
    I changed my fuel, and touched literally nothing. Now my motor will hit 5000 with no load which is where I want it to be (yes I have all the proper stuff done), but why the heck is it getting there now when before it would only hit 3800??!?
    Also before it would idle just fine and now it shoots way up in rpm at 'idle'. If I pull back on the governor arm it comes back down to idle.
    Anybody have any ideas? Been two months getting to this point dealing with getting screwed over by 'mechanics', I'm getting close to wanting to walk away from it!
    Sep 2013
    Waldo Wi
    941
    Well if (yes I have all the proper stuff done) then it has to run right, Head work done etc and still running the governor, stock carb?
    Not enough info here for me to get my head around..
    A Mechanic and a engine builder are many times two different animals
