Bead Lock Rings
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 57
Thread: Bead Lock Rings
  1. #21
    Dec 2012
    Youngstown, Ohio
    1,003
    They are fairly expensive unless I have a bunch made. Last year I had about 10 sets made and the price was good. I can have one set made but I would have to get a quote. The turn around time is about two weeks.
  2. #22
    Sep 2012
    Hanover,PA
    1,012
    Is the inside ring drilled to be Tapped or do you need to put nut behind it for the bolts ?
    I have two sets of wheels at the shop in 8" and some 9" also.
    I am thinking of two sets for the 8" wheels. but would want the Scalloped. Hope some others jump on board as well. We recondition wheels here at ReWheel so if others wanted there wheels upgraded I can do that for them here.
    Maybe that way we can get more orders for them ?
  3. #23
    Dec 2012
    Youngstown, Ohio
    1,003
    Quote Originally Posted by wedge View Post
    They are drilled and you put a bolt through with a nut on the back.
  4. #24
    Dec 2012
    Youngstown, Ohio
    1,003
    Bead lock rings
    I just sent in a request for a quote for some more bead lock rings if anyone is interested. I don’t know what the latest price will be but I can tell you that in July 2016 I was quoted:
    Scalloped $17.08 each
    Non-Scalloped $16.61
    These are for 8” wheels
    Depending on price I plan to get a set or two for myself.
    When I get the new quote I will let all of you know. For now I just want to get an idea if anyone else is interested. The more I order the more the prices drop. After I get the quote I will give it a week or two before I put my order in. Let me know.
  5. #25
    Dec 2012
    Youngstown, Ohio
    1,003
    I just got a quote back and the price for the non-scalloped is still 16.61 each. I also got a quote for two sets and the price dropped significantly. That price is 12.62 each. Like I said, the more I can order the lower the price gets. These prices are good for the next 30 days. Let me know.
    FYI when I say a set I mean 12 pieces.
  6. #26
    Dec 2012
    Wildwood Fl
    126
    what keeps the bead on the inside of wheel from separating? do you only need to do outside?
  7. #27
    Sep 2012
    Hanover,PA
    1,012
    The outer tire bead is Sandwiched between the outer lip of the rim and the new outer ring. You need 2 as 1 is welded to the rim and 1 bolted to it from the outside.
  8. #28
    Dec 2012
    Youngstown, Ohio
    1,003
    I am getting ready to place my order for bead lock rings. If anyone needs a set time is running out. Thanks
  9. #29
    Dec 2012
    Youngstown, Ohio
    1,003
    I only have about a week left to place my order before my quote expires so if you want a set let me know. Thanks.
  10. #30
    Dec 2012
    Youngstown, Ohio
    1,003
    Last chance guys. I am getting ready to pull the trigger on this. I don't want to leave anyone out. I can order them any time but like I said, it is cheaper when I order a bunch.
