4 Stroke engine mount plate for attex
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: 4 Stroke engine mount plate for attex
    Jan 2014
    clifton IL
    813
    Ok guys is Richards the only guy out there making and selling engine mount plates to convert from 2 stroke to 4??? Any info on this would be greatly appreciated!!!
    Thanks
    Dave Phelps
    Nov 2009
    Michigan
    730
    Let me see if I can find some pics. We made them for our Attex's out of unistrut and a flat piece of steel for the base. Never had an issue and lots of adjustment. Not the greatest pics but you would get the idea.
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by Toys4Me View Post
    Wow! you eliminated the angle mounts i see,will unistrut hold up on 20hp twin ya think??? like the torque of trail riding is what I'm asking??
    Thanks again!!
    statesville, north carolina
    2,604
    Dave, are you dealing with a 4 chain, or a 6 chain machine? Ive done mounts for both setups. 6 chain 4 chain In either case, the are comprised of angle steel and flat stock. I mill slots side to side for clutch alignment, and use the stock slots for front to rear adjustment
    Jan 2014
    clifton IL
    813
    It's a 4 chain machine Mike,I see you left the wedges in.were you able to fit motor cover over that twin?
    Thanks Mike
    Buffalo, NY area
    2,968
    Quote Originally Posted by dave phelps View Post
    Thanks Mike
    I'm Mike. He's Brian. We look a bit a like, but he got Dad's brains and I got the babysitter's youthful glow. He modded the engine cover to fit over the Vanny.
    It doesn't need to be that flat, but it holds beer a hell of a lot better that way.
    Jan 2014
    clifton IL
    813
    [QUOTE=hydromike;207051]I'm Mike. He's Brian. We look a bit a like, but he got Dad's brains and I got the babysitter's youthful glow. He modded the engine cover to fit over the Vanny. [url=http://www.6x6world.com/gallery/wild
    Lmfao!!! Sorry about that.. so if I mount with wedges it's not gonna clear the stock engine cover then is it? If i make the mount lower off the frame it might have enuff clearance for cover without mods?
    thanks not saying names anymore!!!!
    Feb 2016
    Mississippi
    1,108
    Dave I have an old mount plate from a Hustler if you want it. It had a single cyl. engine in it. It may be just as easy for you to fab something from scratch, but you can have it if you want it.
    Buffalo, NY area
    2,968
    The problem with trying to mount it lower (without using the wedges) is that the engine will interfere with the left rear drive chain. There are other ways around it, but it includes getting an idler sprocket in there to route the left rear chain lower. This is why some folks start with 4-chain frame when trying to mount a taller four-stroke engine. The other option is to just build an engine cover from scratch. Not too hard, and they work well.
    2,604
    My brother Mike pretty well covered it, but here is how much the engine cover missed by. I mocked it all up with a Honda, but ended up using a Vanguard instead
