MAX II engine cover
Results 1 to 10 of 10
Thread: MAX II engine cover
    Aug 2007
    Felts MIlls ny
    12
    MAX II engine cover
    Looking for a engine cover for a MAX II.
    Sep 2012
    Hanover,PA
    1,012
    What Year ?
    Is it the Flat plate or the Hump cover ??
    Aug 2007
    Felts MIlls ny
    12
    hump cover.
    statesville, north carolina
    2,604
    again, what year/ what engine. Hump cover to go over a modern briggs/ kohler machine, or the small one to go over the valve cover on an older Tecumseh equipped machine?
    Sep 2012
    Hanover,PA
    1,012
    No Problem
    If your not sure on the year give us the Searieal # on the plate on the dash.
    Or easyer yet if it has a Briggs 14 to 18 engine in it ?
    Someone here will be able to hook you up !
    Good luck and when you can Post pics of your ride !
    Aug 2007
    Felts MIlls ny
    12
    1984 max II 440 2 stroke.
    engine swap to 14hp briggs vangaurd
    Sep 2012
    Hanover,PA
    1,012
    OK Now we are in the park !
    So you may need to FIT a newer cover to it ?
    Can you up load a pic so we can see what your working with ?
    Aug 2007
    Felts MIlls ny
    12
    basically I will cut my upper body that had the small flat plate to fit the new engine cover. I don't have any pics machine is still apart, bare frame is on a table getting inner axel bearings installed and frame painted.
    Sep 2012
    Hanover,PA
    1,012
    Well at this point if you can't find a factory Hump cover I would make a Top filler cover unless you want the tube carrying section.?
    Some guys run with out them to let the heat build up out and I have seen some cut the whole floor out and make a top cover so it was easy to get at the engine and drive . It's all in what you want in the end product ?
    Aug 2016
    North of Twin Cities Minnesota
    22
    I sent you a PM if you still need a cover.
