Oil blow back on 84 IC with kol twin series II
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 54 of 54
Thread: Oil blow back on 84 IC with kol twin series II
  1. #51
    That angle looks to be the screw itself, a shorter screw?
    Or drilling and tapping a new hole from the top.
  2. #52
    how does your throttle spring back like that??
  3. #53
    Feb 2016
    Mississippi
    1,108
    Absolutely. Get rid of that lock screw and replace it with a set screw. That will give you much more clearance. If you need even more clearance, punch a new hole in your air cleaner housing to relocate the tupe. Go to your local hardware store and get a solid rubber grommet to plug the old hole.
  4. #54
    Nov 2015
    Central Manitoba Canada
    110
    curtis, if your throttle is not springing back, it could be a week return spring(replace spring) or a seized cable(lubricate or replace) or like my old cable it had frayed and was binding.(replace cable)
