Oil blow back on 84 IC with kol twin series II
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 54
Thread: Oil blow back on 84 IC with kol twin series II
    Nov 2015
    Central Manitoba Canada
    110
    Yesterday was out for a ride and at one point noticed oil by the vents on the hood, stopped the machine and found that oil had blown back from the rubber tube from the block to the air breather. what would cause this all of a sudden? checked oil, levels good.
    One more thing on this post was was doing a lot of grader ridge climbing, steep ups and steep downs ie > 45 degree climbs and drops , could this be a contributing factor?
    SOLVED page 4 Update 4
    my kohler magnum had the breather tube disconnected from the air-cleaner and stuff was blowing out of it,does it always do this?
    whats the purpose and how do the oil breather work?
    Sep 2012
    Hanover,PA
    1,012
    That's the crank case breather and it is suppose to vent to the air box. If your getting a lot of oil out of it your oil may be to full or thin. Unless your getting a lot of Blow by ??
    A lot of WOT running can make you get a little also.
    Nov 2015
    110
    ill have to clean up the area and see if it does it again
    5,049
    Check the compression.
    Nov 2015
    110
    Look for low compression indicating ring problem??
    Ontario-Prince Edward County
    997
    Quote Originally Posted by Aahicnow View Post
    yes
    statesville, north carolina
    2,604
    Also do a leakdown test. a very clogged air filter will act like a choke, and can cause oil to be pulled in there as well.
    Nov 2015
    110
    Can try but the tube is only basically sitting under the air breather by another hole, no real seal to the air breather box, the original connection spot on the air breather was interfering with the throttle cable(binding on cable at full throttle) so it had been moved. This is part of reason blow back was on hood and not all over the inside of the breather. PS tube was moved to postion in pic to see what was happening normally it was sitting under the breather
