Intek engine?
Results 1 to 10 of 14
Thread: Intek engine?
    Jun 2016
    Newville, PA 17241
    568
    Intek engine?
    Is anybody using an intek v twin? I had an offer for a 26 horse and thought that should be more than enough power, not really finding much info online other than it's not as good as a vanguard and is more of a consumer grade as opposed to commercial grade. Would it be worth using in a max ii or ould I be better using one of the opposed twin I/c engines I've found and have some boot left to invest in chains or bearings or any other upgrades I deem fit for this project? Thanks again guys
    No matter what you choose be certain it is a horizontal shaft engine with either a 1" preferably or 1-1/8" shaft 2-3/4 to maximum 4 inches long, I don't recall ever seeing a twin Intek Horizontal.
    Sep 2012
    Hanover,PA
    1,012
    I My self would stay away from an opposed / flat twin. Thy take up ALOT of room !
    Jun 2016
    Newville, PA 17241
    568
    I'm going by what the gentleman told me, I did do a 26 horse intek search and v twins came up but I don't know much, just enough to be dangerous.
    Jun 2016
    Newville, PA 17241
    568
    [QUOTE=wedge;216135]I My self would stay away from an opposed / flat twin. Thy take up ALOT of room ![/QUOTE.
    Yeah I was worried about that, I'm sure with custom motor mounts it would be doable but my center of gravity would in turn be higher, at least the "easy" way it works in my mind.
    Jun 2016
    Newville, PA 17241
    568
    ArgoJim thanks for the heads up, I've been looking at alot of 1" shaft engines. And thanks for the length answer also it was a question I asked in another thread.
    Sep 2012
    Hanover,PA
    1,012
    With the "V" Twin you will be able to get motor mount and so on as thy came with that engine in them.
    What are you looking to spend as I have a Briggs 16 hp With a clutch already on it.
    It has had the Gov removed but there again you can put one back on it.
    I am in Hanover PA so not all that far from you I think ? You can PM me if you would like ?
    It runs Very good and I was holding on to it incase I found a Project like you have on your hands.
    Jus let me know.
    Jun 2016
    Newville, PA 17241
    568
    Quote Originally Posted by wedge View Post
    Jus let me know.
    Hanover is close I'm near Carlisle, pm sent.
    Sep 2012
    Hanover,PA
    1,012
    back to ya ! I was just up to Carlisle for the Mopar show.
    I will call you this weekend.
    Jun 2016
    Newville, PA 17241
    568
    Roger that, I apologize for any delay this mailbox is quite a bit different than what I'm used to.
