18 horse power Vanguard high rpm miss
Results 1 to 8 of 8
Thread: 18 horse power Vanguard high rpm miss
    Jun 2016
    Edgerton, MO
    278
    This is probably a stupid question but is this mouse damage enough to cause a miss?
    Sep 2012
    Hanover,PA
    1,012
    It can as the Voltage will leak through and lessen the spark out put at the plug.
    But this will happen and Low rpm also. when are you seeing the miss ?
    Jun 2016
    Edgerton, MO
    278
    Close to max speed at wide open throttle, governor is stock never touched it
    Sep 2012
    Hanover,PA
    1,012
    Ok that helps ! Is it a spark miss like flipping the switch or Fuel miss like Leans out and starves one bank ?
    You can look at the plugs also. If thy are White and clean it is Fuel. Black and sooty then Spark.
    Sep 2012
    Hanover,PA
    1,012
    OH and get a CAT or a mouse trap as the mice tend to make you spend money !!!
    Jun 2016
    Edgerton, MO
    278
    Right on, pulled plug on that cylinder, was black and sooty, front plug looked good, this engine only has about 6 hrs on it. Just put new coil on, off to test drive...
    Sep 2012
    Hanover,PA
    1,012
    That is SPARK for sure !
    Let us know how it turns out.
    Jun 2016
    Edgerton, MO
    278
    Much better now! Thanks Wedge.
