Hello kensnarr, welcome to the forum.
My name is James, and I live in North Carolina. I just inherited a max 2 from my father in law. It stopped running so where it quit is where it has set for about 10 years, out in the weather of course. I am trying to get it going again, and have ran into a problem. The t20 will not shift at all. It is stuck in reverse and will not budge. Anybody have any suggestions on what might be the problem?
Hello SwineSlayer here. I bought a hoot saterday. It was said to be a 2013 with 30 hours on it . Backed it off the truck and went to the river! It had a hard time climbing hills. Im going to try to adjust the belts but i was wondering if anyone had an imput? I will make it work and become an amphibious owner . Even if i have to change transmissions ? Was i hoot-doed?
Hello James, welcome to the forum. I would start by checking the diamond shifters. Search the forum and you should be able to find several threads detailing what to do. Here's one to get you started: http://www.6x6world.com/forums/trans...tml#post108640
Hello SwineSlayer, welcome to the forum and congratulations on picking up your Hoot. I think you're on the right track. Start with the simple things like making sure the belt is adjusted properly and also make sure it wasn't wet/slipping.
Thanks for the info on the diamond shifters. I pulled them out today( one easily and the other a pain). Got them back in and seems to be shifting fine. Is it normal to have to rock back and forth to change gears?
That is normal for a T20. It will become second nature after a while.
Good deal. Thanks for the info.
Hello
Thanks for the add . My name is Mark I live in Hartford WI i have a 2004 Bigfoot.
Hello Mark, welcome to the forum.
