Alternator on clone engine
Results 1 to 6 of 6
Thread: Alternator on clone engine
    Jun 2016
    Newville, PA 17241
    568
    Have any of you added an alternator to your Honda clone engines? Im going to need the extra juice when I get my max buttoned up since I'm going to have enough lights that it will probably look like a space ship plus, cb, stereo, winch, heater fan, and 7 inch fan to help cool in the summer time. If I can I'd like to just put a v belt pulley on beside my clutch, just seems easiest I should be able to find a 1 inch shaft keyed pulley just about anywhere local. That is if there's enough room to mount the clutch with a pulley behind it.
    DanW
    I just got the Duromax 7HP with electric start, I'm putting it in a small scale jeep I'm building to run around in, I want to hook up a set of head lights but there's no wiring diagram that says what wire does what. The battery cables are already connected so really I just have to install it and get a battery. Can I just run power straight from the battery to a fuse box with a switch in between to cut off power to it when not in use? Then run my lights off the fuse box? Any diagrams or suggestions will be greatly appreciated.
    Feb 2016
    Mississippi
    1,108
    20171016084823.pdfHi Buck maybe this will help you out. Pardon the poor quality.
    Nov 2009
    Michigan
    730
    @DW89XJ, I added a 35 amp one (1) wire mini alternator to my 22hp Predator Maxll. I cant figure out how to post pics, but text me @ 7 seven 0 three 1 8 five seven 8 six and I will send you pics.
    Jun 2016
    Newville, PA 17241
    568
    Hey sorry I haven't been on in awhile, I'll text later today it's currently 537 am in south central Pennsylvania, thank you very much for the help.
    DanW
