JLO 295 and JLO 330
Results 1 to 7 of 7
Thread: JLO 295 and JLO 330
    JLO 295 and JLO 330
    Can someone tell me the differences between these 2 engines?? I have the opportunity to purchase either of these for my Attex 297 and don't know if there is a reason to get one over the other??
    Aug 2008
    Reno Nv..
    36
    isn't the 330 a twin cyl? i thought the largest available single was the 297?
    Northern VA
    2,765
    Are you sure it's not a 340? If it is, it's a little more power and torque than the 297.
    JLO made a 340 and a 380 single cylinder as well.
    I am running a JLO 395 single in an Attex. I have not been able to find out much about it. It makes nice power, but requires good gas. It shakes bolts loose everywhere!
    May 2008
    Putnam, NY
    1,074
    Groundhog. Is it the JLO 295? I have never heard of a 395 before. I have the same engine in my Attex Wild Wolf. Once tuned or jetted properly, it's not bad for a single 2-stroke, it actually supprised me. Still, thread-lock is your best friend. What Carb are you using? Tillotson or Mikuni?
    Attex Super Chief - Sold.
    Yes, it is a L395 Wild Wolf. Wonder if some were put in at the factory? I always thought it was odd that the serial number is 395-001 on the block. What are the numbers on yours? It has a mikuni carb. Can you pull start yours? I am not able to on mine, feels like a 4 cylinder wisconson.
    May 2008
    Putnam, NY
    1,074
    Well, you got me thinking, and I started searching, and wadda-ya-know, an L395 single! I don't know if it was factory or not, my guess would be no, it was added as an upgrade. Mine is a L295, I was going to hunt down some 340 single parts to get more out of it, now I want to go for the 395! Yes, I can pull-start the engine. Maybe yours is not broken-in yet? You should be able to pull-start it. Maybe not easily, but should be do-able. Even larger twins have pull-starts. Mikuni is a good carb, and should run nice once tuned. Do you have a jet kit? One thing about them is you need a Jet kit if you want to get into tuning it.
