Hi All
I have a 24 HP vertical shaft engine with a slight starting issue.
when I turn the key the starter seems to do a slight turn then nothing. when I turn the key off then on it will start with no issues. someties it takes 2,3, 4 times of going back and forth before it turns over. sometimes if I just hold the key in th eon position it will eventually turn over.. it will start fine, just having issue with the starter turning over. makes no diff if engine is cold or warm.
1. could there be an issue with + wire from solenoid to started is corroded?
2. could there be an issue with the + wire going from switch to solenoid?
3. possibility of the starter brushes going bad?
I am going to start digging into the issue this week and a looking for a direction to go.
this issue has been going on for a couple of years but seems to be getting much worse now.
Thanks
Larry
