i have a skidoo tundra 300 with reverse. i noticed that when riding and i stop or slow down the engine will be sputtery and bog down unless i keep the throttle to her and sometimes will just be sputtery and giving throttle bogs down more and wont come out of her sputter. i took apart the fuel pump last year to find it was full of ice??? it has a new plug.i have not cleaned carb yet and the compression was good when we tested it! im guessing its carb but never looked into it yet.any ideas?
If you have ice in the fuel pump you must have water in the fuel dump about 6 ounces of methanol into the gas tank and some sea foam in also. It should solve your problem. If not you may need to flush out tank and lines
