Put some work into getting the Kohler ready to pull. With most of the bits out, i could take better measurements. That big v4 750 is going to be a squeeze!
I’m not sure if it will fit lengthwise. Its a good 8-10” longer than the Kohler and the Argo transmission might be an issue, space wise. Theres room in the tub to go further forward with the v4, but its hard to say how tight a fit it will be until I actually set it down in the engine bay. I also don’t want to get the front cylinder header pipes too close to the plastic hull. I may end up having to see if I can sneak the argo transmission back a few inches, but there’s precious little room for driver and passenger legs in the front seat already.
Height of the V4 is also a problem. Well, it’s not a problem if I dont use hood. Yeah...that's not going to happen!
I will have to modify the airbox. It’s just too tall with it sitting down in the engine V between the cylinders. But it only means making a cut and rotating the front half of it down to level. I can then plastic weld a patch piece in and there should be minimal disruption to the airbox other than added volume (not always a bad thing!).
The hood I have a couple options. I can make a spacer to pop the oem hood up about 3-4 inches:
But I have to leave the rear lower than the front in order to still be able to lower the windshield and still get the height I need in the front to clear the V4.
Second and third options are I can mount the fiberglass hood facing forward or rearward:
Opening facing forward still doesn’t look right to me and the hood slopes to the back pretty severely to clear the windshield pivot. I’m also not sure how to make the opening look like anything else besides “unfinished, even if I add some kind of meshing. I could make it look like something finished, ut it will always stand out as “odd”. The angles are just all wrong.
Open rearward still looks the best, but the front still looks pretty high. The scoop is actually sitting level across the top as it has a taper built in to it for the “scoop forward” orientation, so the “nose high” is a bit of an illusion from the angles.
I think I’m still going to go with the rear facing fiberglass hood. The front I can mitigate the “blocky look” by sculpting the side and leading edge to more of a taper to meet the body and the V4 engine is only about 10” wide at the air cleaner and heads. That means I may still have to make a “bump” in the middle at the front, but that's pretty easy to make look OK on a hood. I might even be a to add the firebird vents to the sides of the bulge to make it look more integrated and pull it all together more visually. IOW: like the bulge is designed to be there.
The v4 swap is not exactly “falling together” like it’s meant to be there, but a plan is taking shape...
