16 hp vanguard throttle/carb linkage
Results 1 to 2 of 2
Thread: 16 hp vanguard throttle/carb linkage
    I just installed a new carb on my engine, I must have not connected a spring/ linkage cause now when I pull the throttle the engine doesn't rev up. before I changed the carb, the springs on my carb/ throttle seemed loose and sloppy.
    does anyone have some pix of their 16 hp vanguard throttle and carb?
    thanks in advance
    tim
    Check out this thread: http://www.6x6world.com/forums/max-a...ttle-help.html Also, double check your throttle cable clamps to make sure they are tightened and that the cable is not slipping when you pull it.
