is any body running a electric fuel pump .i was thinking of putting a electric fuel pump on my 1983 16 hp argo what psi to run ? or should i stay to the pulse pump
thanks
thanks
You will need a regulator that is a 0-4or5 psi
The pulse pump generates about 3psi
Jeff
02 Argo Bigfoot
I have one on my 1985 Argo 8x8. I love it.
Here is the thread on it http://www.6x6world.com/forums/argo-...pump-help.html
thanks
I would not go over 1 psi. B&S has a pump which I would recommend. I put one on my Bigfoot and it worked very well. But I then ran into battery generator problems. No battery, no fuel. So I would only recommend on models which have an alternator.
I still have my mechanical pump. The electric one is just an auxiliary one that I only turn on when I first start the engine or for help on steep hills.
