hey friends...i would like your thoughts on this. if the tightness of the chain can be done by pulling the axle like on the rear wheel of a motorcycle ( slotted holes ) is there any need for a tensioner ? this is
hey friends..i would like to hear your thoughts on this. if you can tighten the chain by pulling the axle back ( like on the rear wheel of a motorcycle ..slotted holes ) is there any need for a tensioner ? this is # 60 chain. i know a tensioner may give a little more chain wrap around the sprocket but not sure that's needed . on my redesign of the subframe on my max 2 highboy i had slotted plates made for the front and rear axles. i can easily put tensioners on but if they are not needed i won't. maybe i just need to give it a shot when the project is done. thanks , johnboy va.
