Wild wolf 295
Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 94
Thread: Wild wolf 295
    Jun 2017
    Robinson, IL
    72
    Ok I'm kinda at a loss. Got spark with correct plug. Evidently have fuel(runs out exhaust). Got compression (150). Timing is firing just before TDC yet it don't even act like it's gonna run. My fuel is probably 1.5 years old. Guess I'll drain it. Not sure what else to do. I just figured it would at least try to run if timing is a little off.
    Dec 2012
    Youngstown, Ohio
    1,003
    Without a dial indicator and a light you are just guessing on the timing.
    Jun 2017
    Robinson, IL
    72
    I'll get a dial indicator. Just can't imagine that's the problem.
    Dec 2012
    Youngstown, Ohio
    1,003
    Quote Originally Posted by 507rzr View Post
    The JLO singles are real finicky. I learned the hard way. When you get the light and the dial indicator check it a couple of times and make sure you have the pin holding the advance or you won't get the timing right.
    Page 28 http://www.vintagesnow.com/Engine_ma...e%20Manual.pdf
  5. #15
    Jun 2017
    Robinson, IL
    72
    I don't have the correct pin. But I make sure the lever is I the advanced position. Or close. Lol
  6. #16
    Dec 2012
    Youngstown, Ohio
    1,003
    I usually use a punch just don't put it in too far.
  7. #17
    It could be the needle & seat stuck open or the floats saturated or stuck.(mikuni carb) dumping to much gas, or even the choke stuck closed.
    You could try shutting the fuel off or disconnecting the fuel line and dump some fuel down the plug hole to see if it will fire.
    sometimes it takes some time to get the all the fuel out of the motor before it will fire.
    depending on what all was rebuilt i would think your timing should be close.
  8. #18
    Jun 2017
    Robinson, IL
    72
    Removed carb and spark plug and drain plug. Cranked over for a few minutes. Allot of fuel mist came out. Put in new plug and sprayed starting spray in intake. Still never tried to run or pop. Guess I will wait till i get the dial indicator that I ordered so I can truly check the timing. Any other suggestions?
  9. #19
    Dec 2012
    Youngstown, Ohio
    1,003
    My money is on the timing.
  10. #20
    Jan 2014
    clifton IL
    813
    Ok. I have 1 question? Have you checked the compression???
    Never mind. Seen it on the 1st post.
