Wild wolf 295
Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 71 to 80 of 94
Thread: Wild wolf 295
  1. #71
    Quote Originally Posted by 507rzr View Post
    Well it runs but floods out pretty quick. Fouls the plug (wet) fuel runs out of the exhaust too. I'm assuming a carb problem. Could it be the floats?
    What carb is on it, mikuni, tillotson, walbro? I assume mikuni, James gerber mentioned stuck or saturated float on first page. If mikuni what size?
    These guys are pretty good at diagnosis with enough information.
  2. #72
    Jun 2017
    Robinson, IL
    72
    It's got what I assume is the original mikuni on it now. I took carb apart. One of the float pins is missing.
  3. #73
    Jan 2014
    clifton IL
    812
    What carb do you have on it?
  4. #74
    Jun 2017
    Robinson, IL
    72
    Now runs great. Until engine gets warm. Maybe 5 minutes. then it dies and no spark. Could the new coil be breaking down. the coil doesn't feel hot to the touch. Let it cool and engine fires right back up and runs great again.
  5. #75
    Jun 2017
    Robinson, IL
    72
    I did replace the carb BTW. I put a new Mikuni on it.
  6. #76
    Th coil could be faulty but unless you found an NOS condenser I'd lean that way from what I hear.
  7. #77
    Jun 2017
    Robinson, IL
    72
    Replaced the condenser. Didn't fix it
  8. #78
    Jun 2017
    Robinson, IL
    72
    Replaced the coil and condenser. still dies after 10 to 15 minutes of idle time. I guess I'll replace the coil by the points next. It did seem to idle fine till I tried to put it in gear and drive it. Then no spark. No pinched wires that I can see
  9. #79
    That was on my mind but I've been away from those engines 20-25 years.
  10. #80
    Jun 2017
    Robinson, IL
    72
    So where does a person find part numbers for parts? I see a few available on ebay but without a part number i don have a way to verify that it is the correct one
