Home made tracks
Results 1 to 10 of 13
Thread: Home made tracks
    Aug 2008
    687
    Home made tracks
    Ok I am new here and as I am good with tools and stuff I was thinking of creating some tracks....
    Anyone here ever do that? If so what was the outcome like?
    Anyone have any suggestions?
    I was thinking of old conveyor belt material and perhaps some UHMW for cross bars ....
    The idea of custom home made is more for fun and education than much else...
    we do not get a lot of snow here but I sure would like to go up the mountains and ride in some during the winter months....maybe to go snowshoeing or something.
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
    May 2008
    Alto MI
    611
    [/IMG]
    here is a pic of a set I made from convayor belt.
    Kevin Hough
    TREBMASTER
    (____>
    .OOO
    Sep 2007
    London, Ontario, Canada
    376
    Track Pics in Gallery
    Go to the Gallery and search using "Tracks" you will see a few versions of home made tracks
    Dec 2007
    eden nc
    1,484
    most use snowmoble belts work great . i think chapy has made some . robbie
    Dec 2007
    Bradford, New York
    251
    Na Mine are super tracks from argo. I don't have the patients to build something like tracks.
    Dec 2007
    eden nc
    1,484
    sorry chap . it was bw6 that made the tracks useing snowmoble belts . and the guy that did the max water jump built his the same way . robbie
    Aug 2008
    687
    Well it would be neat to make a set... just to say ya did it.
    - It is finding some tracks that are the same in reasonable condition that is the first problem.
    - Getting the linking pieces would be the second problem
    - getting the parts to keep the tracks on the tyres the 3rd n final problem
    Assembly would be time consuming and rest assured from the pictures no simple task but well worth the effort.
    I will check with the local snowmobile dealers for potential track solutions
    As for the linking parts no idea where to get em same with the parts that hold the tracks on the tyres....
    For now these are only in the planning stage because until I get clearances figured out there just may be no room for em! who knows?
    MUSCATEER 6x6
    Al "Camo pants"
    Jan 2011
    Fremont, MI
    17
    What about the old jiger tracks? They were just made of conveyor belts that had half moons cut out of them. I did see some pics of these, but wondered how they ever held up? Maybe someone here has had them back when they had a jiger?
    Northern BC
    2,990
    I didn't make em, but these are made out of old conveyer belts
    The connectors are easy to get, Wood/Pulp Mills use them every day, and the guides are easy to make but time consuming. The guides on mine are Factory, but I still don't know who or where they were made.
    Sep 2007
    376
    Quote Originally Posted by riotwarrior View Post
    1. You need 3 or 4 used snowmobile tracks. Your can use any make/model, but the standard size is 15" wide x 121" long, so tape your circumference either 6x6 or 8x8 to determine how many track segments you need. Remove any studs. Here is a link to a local company here that is a snowmobile/ATV wrecker (recycler)
    Snowline Sports
    I paid $10.00/each, check your local or state sources.
    2. To link the track segments you need a heavy duty continuous hinge. Here is a link to the company Spaenaur - CONTACT SPAENAUR
    The part number is B-765 check it out from their catalogue here is the link.
    http://www.spaenaur.com/pdf/sectionL/L112.pdf
    One length 84" is enough to do a complete of tracks cost is $68.50, you will need to drill or punch holes in this hinge and connect with 1/4" bolts.
    3. The track guides are bent angles bent up from flat bar with a slight bend at the tire wall end away from the tire sidewall. 2 hole are drill in the horizontal leg of the guide, then attach them to the track at every second pitch. 1/4" bolts work fine. Check some of the pics in the gallery. But you need at least 4"-5" of vertical guide to keep the tire guided properly.
    Good Luck!
