bought a hustler cheap!
Results 1 to 4 of 4
Thread: bought a hustler cheap!
    Jul 2018
    Palm Bay, Fl
    11
    I got a hustler off ebay for $107.50! I have two max II's and a max IV for our 41 acre hunt camp/swamp land. my question is what size chains do I need as the previous chains were cut off. I saw for the front and back chains I need #50 but what about the T20 to center shaft? I believe the Max units use different sized chain. any help would be appreciated!
    Jana
    Northern VA
    2,766
    Should all be #50 on a T20 Hustler. Nice find!
    Jul 2018
    Palm Bay, Fl
    11
    Sweet, Thank you! I see your a two stroke man any reason I should not run one of the rotax motors that came with it?
    Northern VA
    2,766
    Quote Originally Posted by 406ci68camaro View Post
    That really depends on what you want it to do. If you're going to ride through mud and swamps for long distances at lower speeds, you'd be better off finding a good-sized four stroke for it, but if you want race it or blast around the trails at speed and make your neighbor scream like a little girl when you take him for a ride, the Rotax will make that happen. As far south as you are, you have to take the heat into consideration as well- two-strokes don't do as well in hot temps as a four stroke will. Good Luck!
