2007 ARGO Avenger fuel pump
Results 1 to 3 of 3
Thread: 2007 ARGO Avenger fuel pump
    Jul 2019
    Flin Flon, Manitoba
    8
    I am new at the forum so maybe this question came up in the past. I just changed the fuel pick up in my Argo as it was sputtering and I am trying to source an after market Fuel pump (just in case the problem it is not solved) The Kohler pump runs 39 psi and i located one after market that output 43-45 psi Can it be used. Also any body knows how many gal/minute is the pump required to move. The reason for the after market is that it is about 1/6 of the price of an Argo Part
    Thanks for any info you can provide.
    Fairbanks AK
    1,456
    The kohler 24 393 52-S Pump is a low volume model. I’m not sure the pressure regulator could handle an automotive replacement pump. I can’t find specs now bit 1.5 liter per minute sounds familiar. I buy the kohler a for less than $150 on line.
    Jul 2019
    Flin Flon, Manitoba
    8
    Thanks Master I may just do that and get a Kohler on line but not from the dealer for the $800 can. he quoted me
