New owner 2010 Buffalo with A few issues
Results 1 to 6 of 6
Thread: New owner 2010 Buffalo with A few issues
    We’ll I traded for the previously thought 2014 Buffalo. Runs good and looks to be not
    Used a lot, but won’t move in reverse unless I pull back on the steering levers. I had hoped I would be breaking my tradition of buying something I had to work on before I
    Got to use it. Anyway, I’ll post pictures later and see what you folks think. Transmission
    Definitely looks more complicated than the Argo I just went through.
    Almost forgot ignition switch won’t shut off engine, should be an easy fix with new switch
    Assembly I would think.
    Figured out reverse problem, found discussion on this forum. I don’t know why the
    Owner didn’t know you had to pull back on levers for reverse. Anyway, I got it for a lower
    Price thinking I’d have to go in the transmission. This forum will be extremely valuable
    For my new project.
    2,632
    sounds like a great machine ...good for you. my engine would'nt shut off when i turned the key , it was just the ground wire came off where it plugs to the motor . have fun, johnboy va.
    Fairbanks AK
    1,456
    The ground wire is probably unplugged at the ignition switch or the engine. I had a customer bring me a max he had owned for two years and never got it into reverse. Ten minutes of training and he took it home without rebuilding the transmission. One thing to do for sure is change the transmission fluid.
    Thanks msafi65 and John Swenson for you replies.ill try to post
    Pictures if I can figure out how to.Do pictures have to come from
    A host site here? Thanks
