Max Buffalo- Tub scrubs left-front tire
Results 1 to 8 of 8
Thread: Max Buffalo- Tub scrubs left-front tire
    Argo
    Thanks
    You have things on track, sag from the half length bar support is a big issue, I had to heat mine supported while cooling then run full length angle along the body like the iv cage.
    Thanks ArgoJim.
    Fairbanks AK
    1,456
    I put a cross brace in front of the bed support in all of ours. tied it to the mount plate for the ROPS. I’m looking for pics. Machines are in storage now. Jacked the body up a lot before final bolts. I see this a lot where people tie down on a trailer over the body and leave for months. I tie down over the axles.
    Msafi is correct, helps a lot.
    In my gallery one is shown under body seam and one through body.
    No.
    But they are some sexy beasts for certain.
    Fairbanks AK
    1,456
    Don’t remove top. Just trim a bit to fit in. Found my old phone think pics may be in there. I have drawings in a notebook somewhere. I just jacked tub side with handyman jack and installed mount bolt. If you grab the ROPs and shake it the whole body moves. After the brace it dosent. With a rub in front it was probably tied down with winch, another no no. You can text me at 907-388-8582. I’ll be able to send pics easier. I will try to post for all to see when I find them.
