First Terra-Jet Project, for a Newbie
Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 91
Thread: First Terra-Jet Project, for a Newbie
  1. #21
    Tacked in place, few more tacks and will clean up the weld, then paint:
    https://photos.app.goo.gl/1Fh6vndLz1JJJcVA6
  2. #22
    Pittsburgh PA
    1,153
    Looking good!
  3. #23
    Got the piece in and painted, still have to clean up the topside welds, but will do that when it's back on it's wheels and easier to get to.
    https://photos.app.goo.gl/ZfUjNADYKutkx2ZU7
    Cardboard templating done and transferred to some new 16 gauge steel:
    https://photos.app.goo.gl/SfxDfZ6kzRznttba7
    Need to make some bends in it and prep for welding. This is going to take some time...
  4. #24
    Pittsburgh PA
    1,153
    That's a lot of welding! I weld small broken pieces of stuff, never anything that large.
  5. #25
    Yes, this will be the largest I have (and likely will ever) tackle in terms of welding. I have done only a few body panels before this, so every job helps build the knowledge.
    While it's accessible, I've painted up the patch on the inside, since floor-boards and frame make it hard to get to once it's in. https://photos.app.goo.gl/C3rXhtDp1VJALPFP7 This is two coats of DOM16, which is a Canadian product (Dominion) that is very similar to POR15, but I have found that it sticks to new metal better. I did scuff the whole panel with a flap-disk before applying it though. Hopefully it holds well.
    I also applied some weld-thru primer to the flange edges' mating surfaces on both the tub and the patch. Hopefully this keeps the corrosion at bay in side the flanges where they can't be treated after.
    https://photos.app.goo.gl/fbZsAfxXuVnxAuts5
  6. #26
    Little bit of welding going on...
    https://photos.app.goo.gl/sDAX2T3spgZKTcHX7
  7. #27
    May 2014
    VT
    520
    Awesome work man! This is one heck of a rebuild, your really steaming forward at full speed.
    Good job with all the pictures.
    Terra Jets are great machines and worth the work, they are very capable off road. Their low center of gravity, respectable ground clearance and all time locked 4x4 with those 27" Max IV tires makes them incredible hill climbers and trail breakers.
    I could have sworn I'd seen pics and discussed with a terra jet owner how they used the same tranny as a Coot, this looks nothing like it. Kind of odd, I must have been mistaken. Since the machines is a simple AWD set up with no skid steer in theory you could always jerry rig a different 2 speed with reverse transmission out of another kind of ATV and link it up with your drive-train.
  8. #28
    Thanks allwheeldrive, if I didn't teach myself to replace a body panel last year, I would never have tackled a job like this.
    Got the piece by the wheel cut out and patched. Now to spot/grind the whole thing until it's water-tight...
    Trying to decide now if I want to buy the parts for the early trans, or a new case for the later one. Waiting for a quote from TJ on this...
  9. #29
    Welding and grinding, welding and grinding. At least I have some help...
  10. #30
    Few updates here...
    Ran out of shielding gas, lots of welding going on. Also got a drain welded in:
    Tub ground out and 2 coats of DOM16 put down:
    also, I'm trying to pull the axle out of the spare transmission, but it won't budge and I'm trying to split it to remove. I can get it this far, but then it won't separate any further... any ideas?
    No clue why my pics all come up upside down...
