First Terra-Jet Project, for a Newbie
Page 4 of 10 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 91
Thread: First Terra-Jet Project, for a Newbie
  1. #31
    More progress;
    Got 2 layers of BoxLiner on the bottom, left out the grit for a smoother finish that hopefully lasts longer.
    Finally got the spar tranny split and pulled the axle through, I had to get at the clips to let it slide off the gears, as I would have broken the case trying to separate it totally. You can see what a PO did to try and get it out originally
    Since it was so chewed, I elected to cut the gear sleeve off of it and now I know why my other one won't budge. The key has welded itself to the sleeve:
    Here's hitting it with a cold chisel and small sledge:
    Guess I will be cutting the other one off too, since I've been pounding on it for weeks...
    Oh, and here's a early axle next to a later one, as you can see, the early one is a little longer. FYI...
  2. #32
    May 2014
    VT
    520
    Lots of good info and pics for anyone wanting to go this in depth in a restore later. Good idea keeping the grit out of the box liner underside. The goal is to have as smooth of a belly as possible to let these machines slide over stuff when they high center. My trick has been to hit the underside with WD-40 right before I take my Coot out into the mud, the difference is night and day, almost seems like it can't get hung up.
  3. #33
    Thanks for the tip AWD, I will lube the bottom before finally heading out.
    Cut the sleeve off the good axle, cut along the key this time and it came loose and can be salvaged.
    My bearings came in for the rear axle, just waiting on the seals and a few parts from TJ, then assembly can start.
    I also have an older clutch brake to put in, it's a little different than the newer models, not too clear what's missing to make it work. If anyone has any pics of this setup, that would be great.
    After the axle and tranny, I will be looking to fit the Vanguard in. Anyone have experience with this swap?
  4. #34
    Still waiting on seals, Louisiana is quite the distance away...
    Dropped the motor in for a look:
    I'm assuming I have to cut the muffler off and somehow get it to 'Y' into the stock exhaust. Anyone have pics of their setup they want to share?
  5. #35
    I'd hate to see you cut that muffler. Is that engine from a Max?
  6. #36
    No, this is a B&S Vanguard, came off a big pressure washer. Wish I could work with it, but it'll be in the way and I need the flanges....
  7. #37
    The dipstick is pointed in the wrong direction, I had to swing it 180 degrees, which means the original bracket is useless. Tried my best to fab a new one...
    Forming some scrap: 20200229_000853.jpg
    Welded: 20200229_002901.jpg
    With paint: 20200229_154318.jpg
    May not be pretty, but should do the trick. Left the original in place, if I ever need to go back to it. If it gets in the way, will cut it off.
  8. #38
    Finally got my bearing seals, time to start putting this basket-case together. Axle is going in through new transmission. First things first, loading up the anti-seize on the keys to avoid it seizing up again.
  9. #39
    Goach, where abouts are you located?
  10. #40
    Near Niagara Falls, Ontario.
