T20 Divider plate removal tool.
Results 1 to 4 of 4
Thread: T20 Divider plate removal tool.
    Hi all,
    While pulling my transmission apart, I found someone had siliconed the center plate into position to prevent leaks... Didn't matter than the oil seals on the bearings were leaking like sieves, but hey, they did and so I couldn't remove the divider.
    I'm not sure what others have done in this situation, so I made up a small piece of 3D printed plastic so I could use a case bolt to lock into the plate and then attach it to a panel pulling hammer and gently tap the center out.
    IMG_20191214_180423_1 (Small).jpgIMG_20191214_180440_7 (Small).jpgCapture.jpg
    There's a STL file I'd like to upload as well in case anyone wants to print themselves up one? Does anyone know how I can upload a STL file? Thanks.
    David.
    Nov 2009
    Michigan
    730
    I dont think you can upload a STL file. You could either share it from a personal cloud storage or maybe upload to maybe thingiverse and put a link to it here.
    Jul 2009
    Cleveland,Oh.
    1,589
    Very clever! Thanks for sharing.
    It's not a reliable location, but here's the STL file.
    http://aunv.blackice.com.au/userfile...d-puller_1.stl
    Hopefully you can right-click on it and "save as"
