After I added a 22" LED lightbar, my internal alternator could not keep up with the demand, so I decided to add an external alternator.
Items Used
Kohler Front Drive Shaft: 24-144-23S http://www.smallenginewarehouse.com/KO-2414423S-D1.html
4.5" Engine Pulley: https://phoenix-mfg.com/V-Groove-Dri...el_p_1551.html https://www.amazon.com/Phoenix-V-Bel...5956893&sr=8-3
10SI Alternator: https://shop.advanceautoparts.com/p/...hTerm=7127-3av
Alternator Pigtail: https://shop.advanceautoparts.com/p/...5841/5472830-p
Belt: Dayco 26" #L426 https://shop.advanceautoparts.com/p/...earchTerm=l426
Installed front drive shaft with 4 metric bolts (don't know size)
Fabricating a custom bracket using old alternator as a guide
Bracket test fit
Testing operation with new alternator
Painted bracket (shiny black)
Installation completed (Yes, that is a car horn)
Once I installed the bracket and alternator, I connected the #1 terminal to the ignition wire found at the engine. My 2000 Max IV used a yellow wire in the harness. The #2 wire was connected to the alternator BAT terminal. The BAT terminal was connected to the positive battery terminal using a lawnmower battery cable.
During testing I noticed that upon initial startup, the alternator is not spinning fast enough to excite. Once the engine is revved up once, it charges at idle. It's producing 14 volts. The internal alternator was not operating during testing of the external alternator. I decided to use a GM alternator because it is readily available almost anywhere. I might get a larger drive pulley down the road.
**UPDATE**
Based on feedback from the community, I disabled the internal alternator by disconnecting the voltage regulator. I also did more testing and found that the external alternator does indeed charge at initial startup without revving the engine to excite. I don't have an explanation for why it did not before, but it does now. I will leave the 4.5" drive pulley in place. The alternator puts out 14.7v at idle.
Items Used
Bracket test fit
**UPDATE**
