mike ...i don't think it will be a flop at all , especially with your metal working machines and creativity . if there are any problems i see no reason you can't address them. it has taken me some time and a few modifications after my highboy frame design to get it finally working great . now it's just basic maintenance and for me i love the the results , j.b.
So, remember when I said I had an idea? no the other time.
I decided to do the boxes a little differently, and I think it's a change for the better.
Chopped up some metal and melted some metal.
YES! More better.
I'll melt metal over the holes I poked for the original bearing mount.
This should be very sturdy. Built in bearing extenders.
Tomorrow I'll get it all glued together.
Nice supports, awaiting final outcome.
Got em all hot glued up today and in my favorite color.
I'm glad I did this, but next time I'll make these of aluminum. Gettin heavy.
Jeez I hate weld spatter. I had bought some new wire (Blue Demon) which I always use, but this time I got it on Ebay. Made in China! not India where it usually is. So I thought the wire was bad, then I realized my torch cup was way too loose and pulling in air from the back. Tightened it up and Voila! no more spatter.
Need new cups.
beautifull work mike..so the exstensions are to get a wider stance ? better axle support ? explain for me , thanks j.b.
do the exstensions bolt to the tub , or are they the tire side. must be the tub , to get your tire spacing huh ? j.b.
Hey JB,
The extensions are built in bearing extensions for the axle/tire.
Just like these,
Only extra support.
Not any wider stance, though it is already 6" wider than stock with the portals.
