T20 Plungers and Drum Questions
Results 1 to 8 of 8
Thread: T20 Plungers and Drum Questions
    Sep 2012
    Dillsburg, PA
    104
    Hi Everyone. I disassembled my T20 this weekend and I have some rust on the drums. I cleaned them up with 600 grit wet sandpaper and they are very smooth, but there are some small pits in the drum. I have read a few posts where they say you should have them turned another post or two that said you do not need to worry about them. What is the final answer on this?
    Also, my T20 is the old popsicle style and the plungers only have one O ring. Should I upgrade these to the later style or are they not easily found?
    One last thing, it appears my T20 was filled with gear oil, not ATF. I heard a lot of racers do this and it is ok and has benefits to using it - like not leaks. Can anyone confirm this? The bands look good but are soaked in gear oil. Should I use gear oil for this since that is what was used before?
    Thank you!
    Oct 2008
    Farnham Ny
    575
    The small pits won't hurt anything if you had no leaks single O ring plunges work just as good as double O ring i have 13 transmissions all single O ring and yes stay with gear lube those older transmissions don't use fiber washers the lube is what protects your drums.
    Sep 2012
    Dillsburg, PA
    104
    Thanks so much for the reply. Can I ask what weight and brand gear oil you use? Thanks so much!
    Oct 2008
    Farnham Ny
    575
    Valvoline 75 85w or 80 90w which ever one the store has that i am at.
    Sep 2012
    Dillsburg, PA
    104
    Thanks so much!
    Sep 2012
    Dillsburg, PA
    104
    Hi. One last question, I hope. Here is a picture of one of the drums in my T20. I used 600 grit wet paper to clean up the rust, and this is what is left. Is this too bad to use without turning or am I ok? Thank you: (https://photos.app.goo.gl/C7nZnUWuPJ4DuFcXA)
    Jan 2014
    clifton IL
    812
    Quote Originally Posted by budzinsk View Post
    I would use that drum.
    Sep 2012
    Dillsburg, PA
    104
    Thank you! That is what I was hoping to hear.
