Did some damage to my control lever.
Results 1 to 2 of 2
Thread: Did some damage to my control lever.
    Stuck in a bad spot last night I was pushing hard forward on my control sticks and the right side something gave. Now the right side is about 4" forward then the left. It still kinda works its just way far forward then it should be.
    I can't get in there to work on it until late tonight but thought I would post to see if I can get any suggestions or if someone has had this happen to them.
    I'm hoping its just a pin or some linkage that has broken and not a tranny or more serious issue.
    Aug 2011
    Kotzebue, Alaska
    1,209
    There are two retainer clips, one at each end. The one at the T20 is meant to be removable, the other is not (but still could pop off if the cotter pin comes off.)
    Perhaps the removable pin popped off, and allowed the shaft to come off the U-channel.? Worth a look.
