Replacing idler chain
Results 1 to 10 of 14
Thread: Replacing idler chain
    Feb 2015
    Haliburton ON
    74
    I have completely frustrated myself trying to put the connecting link into a new idler chain.
    The new chain has no slack and I cannot line the two ends up to insert the pins of the connecting link. Does anyone have any tips?
    Not sure why Bob this is with the motor plate adjusted all the way down any idler chain I ever bought out of Argo had plenty of slack with the motor/Trans plate all the way down.
    I do use a pair of modified vice grips on nasty chains
    Feb 2015
    Haliburton ON
    74
    I checked the Argo part number and it?s the correct one. The transmission is as far down as it goes. However the manual does say to remove the power pack adjusting bolt completely to provide better access. I will try this. Maybe that will give me more slack.
    Have you a modified vice grip simple build helps tons I guess my sprockets are worn more than yours is the reason I get slack I just installed all new chains.
    Dec 2018
    Muskoka, Ontario
    95
    Check the power pack frame for a second lock bolt between the engine and transmission. I have run into this same problem before and that was the culprit.
    Texas
    2,161
    This is what I use:
    I have one for #60 and I ground another one down for #50 chain.
    Feb 2015
    Haliburton ON
    74
    It looks like I will have to buy a chain tensioner or the Argo vice grips to finish the job. Thank you all for your help.
    Dec 2018
    Muskoka, Ontario
    95
    Be careful pulling those chains too tight. I've had the idler shaft bearings go and the teeth on the brake rotor wear off because I adjusted the chain too tight. Check for another big lock bolt that you may have missed. Those chains should be fairly loose if everything is adjusted all the way down.
    If you have both center and rear bolts loose and have pushed down on power pack with leverage and still a no go, first check that the square washers are flat and not standing, if that doesnt work you may want to loosen the front bolt.
    This is all assuming you have adjusted down the the 2 height adjustment bolts.
