18 hp Vanguard Idle Problems....any advice?
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: 18 hp Vanguard Idle Problems....any advice?
    Jul 2008
    Central, Kentucky
    15
    Route6x6.com - 6 and 8 wheel ATV how to's - Vanguard Carburetor Cleaning
    If you had all this trouble with trash in your gas tank I imagine sooner or later you will have to get into the carburetor itself. This How-To Guide Is from Richard Relics it's a well written and easy to follow instructional guide cleaning the carburetor on the engine. Although this guide is written for a max. We followed these instructions on my Max and solved a similar problem. These smaller gasoline engines take smaller Jets, air passageways so it doesn't take but just a tiny piece of grit in the wrong place to get lots of problems.
    Tulsa, OK
    1,725
    Overlooked by that guide is the idle mixture screw, which needs to be removed and cleaner sprayed through. It's on the side of the carb facing the pull start. Compressed air along with a strong cleaner, like Berryman Chemtool works good. The plastic cap mentioned earlier is on this screw. Pull it off and toss it. It's an anti tamper device that limits your ability to adjust the idle mixture right. After cleaning, turn it in till it seats gently, then turn outward 1.25 or so turns. Adjust from there at idle.
    Sep 2008
    Gold Hill, NC
    19
    I left it out of my original post because I had to double check that I was right first, but Ken had already cleaned the Carb last week when he replaced the filter and pump. He told me today that he doubts anything has made it past the filter and I do too. So, hopefully if I just work from the filter to the tank I'll get it resolved. I'll defintely keep the link to that guide for future reference though!
    Thanks again,
    Andy
